Installed TTR Sway Bar
Solman- TTR bar looks good...How do you like it ??
For the guys trying to get on ramps, I use 1 piece of 2X6 in front of each ramp. Gives you a bit of lift before the 'chin' reaches the ramps. Length depending on your vehicle.
Cost = $0. scrap lumber..
sleeper
sleeper
With the 225/45's, I'm 7.25 from the ground from the black air deflector. These tires are almost 1" taller than the 225/40's I was running. The are indeed Rhino Ramps, I think they were the 5000 lb models. But the label is no longer there. So I would think they would work with the SS front fascia. I never hit mine, even coming off them.
