Just a inch or so
Originally Posted by cyberone3
but it needs to be a reasonable pricen 2 springs for the price or a full set you could possibly get a full set of coilovers and set it that way also
Remember this: whenever you take a stock height suspension and lower it an inch, or inch and a half, you are "increasing the spring rate" as the physical geometry of the suspension has not changed. Using this logic, lowering only the rear of your vehicle will net you a very uneven ride; soft in front and stiff in back. This can cause handling inconsistencies in fast/banked turns, during hard braking, and emergency manuevers. Adding a fully matched kit ensures your car handles well and has an even ride and handling.
It boils down to the old adage; you get what you pay for.
Hope it helps,
Ground Force They have this kit and a whole lowering kit but it is to expensive compared to Eibach and Gold-Line. It comes with an alignment kit though. They told me this leveling kit is designed to work with the stock front springs and will handle just fine. I have put a few of their kits on, and have installed dozens of their 2 inch shackles. Very good quality, no cheap ebay knock-offs sold in my shop
