Leaking shock?
Old Apr 14, 2010 | 06:13 AM
06Daytona's Avatar
Leaking shock?
I noticed a large wet spot in my garage and also in the parking spot that I use everyday at work. It is located underneath the driver's side rear shock. Looking underneath revealed that the lower half of the shock was completely wet with an oily substance. I have not noticed any difference in ride quality.
Is the shock shot?
If so, could I replace it myself?
Should I replace both rears at the same time?
What is the average cost for this type of job?
Thanks.
Old Apr 14, 2010 | 06:24 AM
Always do both shocks if one is needed and if it's leaking to the point of dripping, yeah I'd say replace them.
Old Apr 14, 2010 | 06:47 AM
solman98's Avatar
Yea, if it's dripping, it's definatly done for. Shock for the most part are easy to replace.
Old Apr 14, 2010 | 07:25 AM
BlackknighT's Avatar
Check rear brake hose/line in that area too. Never know when a pinhole happens and shoots a little fluid...
Old Apr 14, 2010 | 09:48 AM
06Daytona's Avatar
Thanks. I didn't think to check the brake line.
If it does end up being the shock, I found the Monroe Sensa-Trac rear shock at Advance Auto for $32 each. Sound like a good deal?
Old Apr 14, 2010 | 10:45 AM
solman98's Avatar
I've used the Sensatrac in the past and liked them.
Old Apr 14, 2010 | 11:16 AM
HHorange's Avatar
Sensatrac or KYB are about your only inexpensive choices.
As for changing them yourself it should be a quick easy change as long as you have a way to safely get the car off the ground and supported as you will want to pull the tires in the rear.....
As a rule you should always replace shocks in pairs.
Old Apr 14, 2010 | 11:53 AM
06Daytona's Avatar
Thanks for the info on the shocks. I'm hoping that's it is the shock.
I do have a floor jack and two jack stands, so I should be able to replace them myself although I've never had to replace shocks before, so this will be a first for me. * crosses fingers *
Old Apr 14, 2010 | 12:13 PM
Qwikhuh94's Avatar
i just replaced the stock shocks last week with the monroe brand and the ride is MUCH better....
Old Apr 14, 2010 | 05:23 PM
SmootHHR's Avatar
Man, I love this site! I just got my car back from it's first service/oil change at the dealership and it said "rear shocks leaking bad...suggest replacement". Of course they'd be happy to do it for me...$265.50+tax please! No thanks, I'll do it myself :) Does anyone happen to have pics of this process?
