Lower rear only?
Old Oct 28, 2007 | 12:02 PM
monza's Avatar
Originally Posted by Premiere07
A rear swaybar is, in my opinion, one of the best things you can do on a FWD car. It gives the car a slight understeer, and makes the car handle a lot differently. If you like any kinda of sprited driving a rear swaybar will give the car a much more stable and controllable feel. I had one on my last car and the difference was amazing.
a rear sway bar will give you more oversteer... which is the reason a lot of cars don't come with it, because your average driver can better deal with understeer than oversteer.
If you do the rears only, do you need to redo the front end alignment?
nope
Old Oct 28, 2007 | 08:59 PM
Premiere07's Avatar
That's what I meant, sorry .
Old Oct 28, 2007 | 09:51 PM
Originally Posted by GER42
Still trying to decide do I lower the rear only or go for front and rear?
Go all the way!
What problems have people had lowering both?
Absoutly no probs w/ the install, nor any since. Dory's GLs have been on for 1 yr come mid Nov.
If I do both do I do just springs? If I do both do I also install rear sway?
I was riding around on just springs for 10 months and w/ the addition of the sway bar handling has improved quite a bit.
I would like it to handle better, be more responsive and have less roll.
F/R Springs and Bar would be best!
Maybe go for a ride in Dory if next meet up is before you decide?
Old Oct 29, 2007 | 06:43 AM
GER42's Avatar
JX3 thanks for the invite. If I get a full set you know anyone in the area to do the install? I'm getting too old for all of this.
Gerry
Old Oct 29, 2007 | 08:11 AM
Gerry
Sorry, can't help you there. Dory's were installed by Derrick, TCRNCOB's (Theresa) son, at a dan'd's home.
Old Oct 29, 2007 | 08:38 AM
monza's Avatar
no worries.
Old Oct 29, 2007 | 10:49 AM
mizzouHHR's Avatar
I have the rear leveling springs on mine, and no you don't have to align the fron end. You will have to adjust the headlights.
Old Oct 29, 2007 | 09:50 PM
bmaker12's Avatar
I installed Eibach sportline springs and Koni shocks and struts. It rides and drives great. I have no problem with bottoming out...
Old Oct 30, 2007 | 08:45 AM
hvrod's Avatar
Using lowering coils only..
Soon your Stock shocks will be like
upgrade the shocks at the same time.....
Old Oct 30, 2007 | 10:12 AM
scaleguy's Avatar
I am lowered and love it...but I lower everything so I might not be the perfect example !!! Low and Slow is the way I go...
