Lower rear only?
Old Nov 11, 2007 | 01:23 PM
GER42's Avatar
Originally Posted by bmaker12
I installed Eibach sportline springs and Koni shocks and struts. It rides and drives great. I have no problem with bottoming out...
Does the rear still sit higher than the front?
spring notes say drop is 1.8 rear 1.6 front
Old Nov 11, 2007 | 02:32 PM
WhiplashHHR's Avatar
nope, it sets even.
Old Nov 11, 2007 | 05:01 PM
GER42's Avatar
Originally Posted by WhiplashHHR
nope, it sets even.
Where did you buy springs and shocks?
Old Nov 11, 2007 | 07:03 PM
1Panel2NV's Avatar
Koni strut inserts
Koni rear shocks
That's about $570 for the full setup.
I'm personally waiting for KYB to release their struts and shocks because the struts will be a complete replacement, rather than cutting up your stock struts to put an insert in. Not that it's that hard to do, it just doesn't seem like it's worth that much to basically make your own strut. Unless you absolutely need better struts right now.
Old Nov 11, 2007 | 07:07 PM
GER42's Avatar
Originally Posted by 1Panel2NV
Koni strut inserts
Koni rear shocks
From the WEB site Shocks, struts, mounts, and boots are sold individually, not in pairs
Old Nov 11, 2007 | 07:12 PM
  #26
1Panel2NV's Avatar
That's where I got $570; two inserts and two shocks.
Old Nov 11, 2007 | 08:24 PM
  #27
GER42's Avatar
Sorry I can't add
Cat Man HHR
7
Apr 3, 2015 12:55 PM
Cat Man HHR
Oct 6, 2014 12:09 PM
retrolled
Aug 14, 2013 08:34 AM
1970judge
Drivetrain (Excluding Engine)
Nov 16, 2011 08:24 AM
dsmisfits
10
Sep 3, 2010 09:41 PM
