Lower/rear mount.
Old Nov 9, 2011 | 02:14 PM
1970judge's Avatar
Lower/rear mount.
Has anyone replaced the lower, rear mount by the rack? I believe it is called a "trans mount"? Any good write ups?
Old Nov 16, 2011 | 08:24 AM
hhrfreek's Avatar
I have been using the poly mounts for a while and they are great so far. They are stiff though. You can use your stock mounts and pry out the OEM insterts. Gotta warn ya they will send a few vibrations through the car when taking off. Not very noticeable at cruising though.
https://www.chevyhhr.net/forums/drivetrain-excluding-engine-57/polyurethane-transmission-mounts-36963/
These are the ones I am using:
http://www.turbotechracing.com/produ...dcategory=5615
Cat Man HHR
7
Apr 3, 2015 12:55 PM
drspock
Apr 11, 2014 07:41 AM
hhrkiko
Mar 10, 2014 06:58 PM
Zagohhr
2.4L Performance Tech
0
Sep 1, 2010 10:23 AM
