Lowering HHR...Week 1 Update
Old Mar 6, 2006 | 06:27 PM
ng8650's Avatar
Originally Posted by SoCalHHR
Hey NG - who did your alignment here locally? Just curious.
Precision Alignment on Del Rio. 699-3159
Ng
Old Mar 6, 2006 | 06:29 PM
O6ChevyHHR's Avatar
Sounds werid when i get my drop i willl take socals input and get the chamber kit, if i dont need it socla can it be returened??
Old Mar 6, 2006 | 06:39 PM
SoCalHHR's Avatar
Sure it can be returned - but you will need it eventually when you have to get you HHR aligned later on.
Old Mar 6, 2006 | 06:58 PM
BIG JIM WOODMAN's Avatar
If you do not need the chamber kit now you will, as the front end wears chamber will then have to be adjusted. this is when you will need it and you better hope it's at hand or already on the car. it may take days before a kit could be located and installed. the best time to install the kit is when you take the struts off! you most likely will not need the kit just because you lowered it,( mine only needed minimal adjustment) there is also the cost to concider, when you are lowering your car install the camber kit. right. no additional cost but the kit. wait until you need the kit and then you may be waiting on a kit to be ordered and paying to have it install. it's no brainer to me.
Old Mar 6, 2006 | 07:02 PM
Skatetheglobe's Avatar
I just ordered my Goldlines so hopefully they will be here soon and I can get them installed..I can't wait.
Old Mar 6, 2006 | 07:08 PM
lowering
are you going to lower it or farm it out! the only special tool needed is a coil spring clamp, or strut tool, both can be rented at your local parts store. about an hour hour and a half should do it. good luck.
Old Mar 6, 2006 | 09:20 PM
Lee3333's Avatar
Just curious (and planning ahead)-do you need the spring compressor for the new springs? Many, many years ago when I did my 280 Z, I needed the compressor to remove the stock springs, but the new springs were short enough to go on with out compressing them (but I REALLY lowered my Z).
Old Mar 6, 2006 | 10:24 PM
SoCalHHR's Avatar
Yes, you need the compressor to unload the strut shaft nut when tightening it during reassembly. If you attempt tightening it under pressure, it will not tighten adequately.
Hope it helps,
Old Mar 7, 2006 | 08:20 AM
Navyflyer11's Avatar
You will need the camber kit if you ever have to adjust the front for an alignment. The stock HHR strut bolts are splined and do not offer adjustment. I recommend putting the camber bolts in when you do the alignment, then they will be there when you do need them.
On the rears, - strange, that's the third person I've heard of who hasn't needed the shim kits in back? Whatever works.
Go for it!
I agree with SoCal, put the camber adjustment bolts in. That way you will have the adjustment available in the future. And the don't cost too much.
Old Mar 7, 2006 | 08:44 AM
I'd like to do it myself but I'm afraid to start and not be able to finish because I can't reach something..Any idea what it costs to have em installed?
