Lowering springs
Old Nov 28, 2010 | 01:53 PM
moonsign's Avatar
Originally Posted by Rainman
For the SS model, Pedders are the best for lowering and handleing
Without a doubt! And I might also add that the OTTPerformance "Hardcore" rear sway bar is the best rear bar. "Moon"
Old Dec 13, 2010 | 02:10 AM
mrsilent13's Avatar
i want both the pedders and ottp bar...but its christmas time...i almost bought both on impulse right now...lol.
but my question is...how much lower is the SS on pedders?
Old Jan 25, 2011 | 12:17 PM
retrolled's Avatar
1st time around with goldlines. Now with colbalt SS/SC springs - haul very little. This is how it should have been made in the first place. Much better ride and one less noise.
What didn't you like about the Gold Lines?
Old Jan 25, 2011 | 03:53 PM
HHR_style's Avatar
< Ground Force >
I too installed the Ground Force leveling springs. Perfect fit & still going strong! Got the Progress tech sway bar too! All working great with zero issues!
Check the install thread:https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/ground-force-rear-leveling-springs-24188/
Old Jan 25, 2011 | 04:21 PM
X2 on the Ground Force, Progress combo. Great handling setup!
Old Jan 26, 2011 | 01:14 AM
Originally Posted by sleeper
Cobalt SS/TC rear springs, & I haul plenty
+ TTR Bar & Like on rails in twisties, & good ride, much better than stock..
Old Mar 18, 2011 | 11:38 PM
LawDog88's Avatar
This is great info, but now my question is, if I get lowering springs, will I have to change the struts?
Old Mar 18, 2011 | 11:55 PM
If you level it, meaning just swap rear springs, easy deal.. 1/2 hour.
If you do all 4, you would need to pay someone to do the labor, & could re-use the stock struts, (Struts are in front) if they are not leaking..+ needed front end alignment costs.
For me & where I live, I leveled mine, & love it.. I've had enough of really Lowered rides, that I made so low you had to watch out for even a speed bump cause it could scrape..
Old Mar 19, 2011 | 12:11 AM
LawDog88's Avatar
So if I just get the rear lowering springs I don't have to do anything else? Awesome.
Old Mar 19, 2011 | 12:26 AM
Only other thing, would be probably minor headlight re-adjustment.. Depending how low you go in the rear. But that's easy as eating donuts..
I think you could do the rear springs yourself & save a few beans too.. Very simple..
