Lowering springs
< Ground Force >
I too installed the Ground Force leveling springs. Perfect fit & still going strong! Got the Progress tech sway bar too! All working great with zero issues!
Check the install thread:https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/ground-force-rear-leveling-springs-24188/
If you level it, meaning just swap rear springs, easy deal.. 1/2 hour.
If you do all 4, you would need to pay someone to do the labor, & could re-use the stock struts, (Struts are in front) if they are not leaking..+ needed front end alignment costs.
For me & where I live, I leveled mine, & love it.. I've had enough of really Lowered rides, that I made so low you had to watch out for even a speed bump cause it could scrape..
I think you could do the rear springs yourself & save a few beans too.. Very simple..
