mounting rear discs...help!
want to switch to rear discs before changing frt ones.
Is the caliper mount part of the rear suspension,or does it
bolt on instead of drum backing plate.
Thanks in advance.
Thanks in advance.
Don't forget to add the master cylinder from an SS to the shopping list, disc/disc systems need a different master cylinder than disc/drum systems.
Prod is correct that there are some conversion threads, but the most comprehensive is ancient, the member is inactive, and his Photobucket account has deleted all the linked photos.....so it's pretty much useless as a reference.
Unless you're driving at 10/10ths, and using the brakes in a competitive situation like Autocrossing, the time and effort to do the conversion are not really worth it.
P.S.
to the forum!
P.S.
to the forum!
