Which are OEM Lower Control Arms
Well I just finished replacing the LCA bushings, ball joints ,swaybar bushings and end links with all new Moog parts. The LCA's are a breeze to remove and reinstall. The hardest part was removing the old ball joints. I have a vertical hydraulic press to do the work with and the OEM ball joint rivets were a bear to press out. After test driving my vehicle the clunks are gone but now I have a clear rattle in the intermediate steering shaft to address. I replaced the rubber sway bar bushings with energy suspensions urethane bushings. I hope that was not a mistake on my part ????
Nope no mistake! The shaft has a history of problems over several GM models,
And here is a replacement part site,
Steering Column Lower Intermediate Shaft with Coupler for 06 11 Chevy HHR | eBay
Control arm replacement
what should I use to replace my control arm steel or steel alloy
question is should I just do the control arms or go ahead and do it all while I'm under there?
Control arms first, we get a discount from RockAuto, I recommend Moog or AC Delco LCA’s. And of course if you’re HHR is an SS the GM arms must be installed, because of the ball joint stub size.
Ordering aluminum LCA's
I have a 2011 LS 2.2 4 I've hot to replace the lower control arms on both sides the bushings are out so I'm going to do the whole control arm I'm really strapped for cash so I'm trying to find the cheapest pair of the aluminum control arms does anyone have any suggestions? also I seen in one of the threads to go get a discount for RockAuto how do we go about that?
ebay or
go to the supporting vendor forum at https://www.chevyhhr.net/forums/supporting-vendors-25/
So I bought the Detroit Axle brand lca's and suspension parts. Not liking them at all. Ride is crap in my opinion plus my alinement is below specs. The shop got it as close as they could but stated they couldn't do any adjustments. So I want/need to switch back. When looking at the parts on RA I see all kinds but it appears most say stamped steel. Will someone list the parts numbers that are the type the hhr requires. My HHR is a 2009 2.2l LS. Even as loose and noisy as my old suspension was, I feel it still rode better.
They're in here https://www.chevyhhr.net/forums/comm...-thread-48833/
