Pulls right letting off brake.
Old Jul 17, 2023 | 09:29 AM
Z0MBIE's Avatar
2010 HHR and letting off the brake the steering wheel jerks a little to the right. I tried new rotors, brake pads and right caliper but same thing. When braking it's fine does not pull or anything just letting off brake after a stop. Ideas?
Old Jul 17, 2023 | 11:05 AM
Look at this
Old Jul 17, 2023 | 01:26 PM
Install them at the same time to both sides
You can press in new bushings , I prefer the Moog K201285 problem solvers
Old Jul 17, 2023 | 02:02 PM
And the "problem solver" control arms do not have the "problem solver" bushings, so don't be fooled. They may have stopped marketing them like this by now, but just a warning.
Old Jul 17, 2023 | 07:54 PM
jimvw's Avatar
don't forget a front end alignment after installing LCAs
I used the problem solver arms when I changed out the junk chinese ones that made things really bad. The Moog problem solvers worked good(and still do) The cheap China ones wore out a set of tires in 3,000 miles...
Old Jul 17, 2023 | 08:18 PM
Some of the "Chinese" arms are a couple of mm longer than stock, causing a 1 or 2 degree camber problem. I could not tell the difference by eyeball. Evidently, they "fit" other cars too.
Masterofnone71
Aug 9, 2022 06:44 PM
RockAuto
Sep 26, 2020 12:30 PM
oldscout
Mar 15, 2015 05:31 PM
Wolfie
Feb 19, 2009 01:03 PM
NikiPowPez
May 19, 2008 12:58 AM
