question
Old Feb 28, 2008 | 06:08 PM
intofocuszx3's Avatar
question
I got the the goldline rear lower springs and the progress sway bar installed and when i hit i bump it sounds like something is banging I have no idea what it is any clue I torque the sway bar to the settings 45 pounds
Old Feb 28, 2008 | 06:22 PM
oneton's Avatar
Did you cut the bump stops like it said? are the shocks bottoming out? and how big of a bump?
Old Feb 28, 2008 | 08:22 PM
no dan cut the bump stops sounds like metal bumping oneton maybe i can stop by and see if everything is ok.
Old Feb 28, 2008 | 08:28 PM
RaceOn's Avatar
This issue has been discussed here before. See the following.
https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/goldline-leveling-spring-question-8241/
You might be in the same boat.
Pat
Old Mar 3, 2008 | 09:56 AM
fontana motorsports's Avatar
they should equipt the gold line with the silencers out of the box, my eibachs did...you can also goto homedepot, or a fish tank supply store and buy the thin line.
betterof2evils4
Apr 3, 2017 08:34 AM
FargoFlash
Jul 12, 2011 04:54 PM
