Raybestos Front Rotors
Old Apr 30, 2021 | 07:59 AM
Silverfox's Avatar
Has anybody installed the Street Performance Raybestos Front Rotors Part number 580382 ??
Looking at the data, they look like a pretty good choice short of the SS conversion option..
Silverfox
Old Apr 30, 2021 | 09:07 AM
For the SS conversion to non Brembo 11.6 inch rotors, you just need the new SS rotors and the SS caliper brackets. Hugh improvement!
But for those that want to just replace the rotors, these will do fine!
Did you look them up in the RockAuto site? And don’t forget that discount code!
for a little more then 2 Raybesto rotors, I would select this kit.
Old Apr 30, 2021 | 10:11 AM
Silverfox's Avatar
Thanks Steve
Let you know what the results are when I get to it.
Using Stock OEM GM HHR Pads.
SF
Old Apr 30, 2021 | 10:16 AM
If you got them use them! Just a suggestion for those reading this thread. The BlackSwan has the GM pads and a set of cross drilled rotors.com 11.6 inch SS rotors . The SS caliper brackets are getting scarce even from Cardone
hurst2001
Maintenance and Upkeep
Sep 8, 2016 01:00 PM
bbautomachine
33
Oct 19, 2015 12:32 AM
alexrckid
29
Oct 18, 2011 12:16 AM
JuMPy
Jun 23, 2008 09:30 AM
R CA HHR
Oct 26, 2007 10:05 AM
