Rear disc
Old Sep 8, 2012 | 10:37 PM
jaytheredneck1's Avatar
Rear disc
SS only? or is it also 2LT? Next pay I'm going to a pick and pull to hunt for hubs, calipers and mounts. Is there anything else I can scavenge them from?
Old Sep 8, 2012 | 10:44 PM
prod's Avatar
You need the whole ss rear axle, no caliper mounts on ls/lt. You can try a cobalt axle with discs, easier to find. And you need the brake flex lines and parking brake. I havent done it myself, so there could be more.
Old Sep 9, 2012 | 08:59 PM
pbatmen's Avatar
Many threads on this subject, I used a 2005 saturn Ion redline rear end, you can use cobalt ss, hhr ss, or ion redline, rear axle. all you need is the rear beam fully loaded which means it comes with calipers, and hubs and everything, same hubs in both axles so that realy doesn't matter, except if your car does not have abs, mine did so it was plug and play. easy intalll with about 2 bolts on each side, one on the chasis and one one the bottom of the shock, and disconecting brake lines. it should only take a hour or so if you are handy and are comfortable with working with brakes.
Chillydip
14
May 8, 2015 07:23 PM
gangster moblie
Sep 18, 2010 09:23 PM
Michael20832
Sep 14, 2008 11:23 PM
Hotrodbob
25
Sep 18, 2007 08:55 AM
PDX HHR
10
May 12, 2006 10:13 AM
