Rear LCA bolt stuck
Old Nov 24, 2022 | 06:17 PM
PulpFriction's Avatar
By Moog Problem Solver, do we mean the one with the ball joint inside? I’ve heard they wear out quickly, but the track guys don’t care because they like the practically zero compliance for mor precise handling. This one?
I was just looking at these two.
Old Nov 25, 2022 | 05:50 AM
Yes and under normal driving conditions they last much longer then the OEM rubber bushings
Old Nov 25, 2022 | 02:50 PM
califphil's Avatar
The gold bushings is what I used. I think the cheapest and easiest part to replace, the sway bar bushings were the cause of my clunking over bumps, there was no play in the ball joints and some wear in the stock bushings, but boy o boy, the car steers so much better now. The motor mount was not visibly bad but I could tell the Glycol had leaked out. About $450 in parts, but it was worth it.
Old Nov 25, 2022 | 04:01 PM
Glycol? I thought the motor mount was just aluminum and rubber.
Old Nov 25, 2022 | 04:30 PM
califphil's Avatar
GM has used liquid filled mounts for years, the late 90's Pontiacs were the first that I had seen them. A leaking motor mount was a strange sight to see. I believe the parts store replacement mount will just be solid rubber. The OEM mount went 131,000 miles and said Glycol filled on it. The new one from GM said the exact same thing. $155 for the mount is pricey, but worth it to me to have OEM.
Old Nov 25, 2022 | 05:16 PM
Huh. Never heard of a glycol-filled mount on HHR. I saved what I assumed was the original motor mount from my HHR SS manual (not assuming the autos had the same p/n.) Need to take a closer look. Replaced with a rather stiff OTTP mount.
Speaking of, that bushing is an LCA bushing.
jarheadbobandmax
Apr 19, 2020 01:31 PM
Kookie
41
Oct 13, 2019 11:12 AM
junker
10
Apr 20, 2018 11:10 PM
fonque
Maintenance and Upkeep
Mar 27, 2017 09:52 AM
crocitto49
Oct 1, 2013 06:57 PM
