Repainting Repainting Brembo's and installing on SS. PICTURES!
Old Jul 22, 2016 | 02:41 PM
Ls2_HHRss's Avatar
Based on the pictures in the OP's other thread, I still don't see that these are going to just "bolt up". Especially don't see the e-brake cable connection being compatible.
The other thread: https://www.chevyhhr.net/forums/brak...-hhr-ss-57304/
Anyhow. Good job on the paint work.
I am hoping though. Isn't the rear set up the same as a Cobalt and our cars?
Old Jul 22, 2016 | 02:44 PM
2009 HHR SS rear calipers are in this picture
They do look somewhat different from the calipers in your pictures
Old Jul 22, 2016 | 02:49 PM
These are 2008 Cobalt SS Brembo calipers the top two, the are for the larger diameter Brembo discs and may have a different ebrake cable
Old Jul 22, 2016 | 03:08 PM
Apparently not. That's why I posted the pictures of my rear calipers in your other thread. It shows how much different the setups are.
I guess I just assumed you would do a test fit before trying to mount them up.
Fwiw. A while back, I got new rotors, pads, wheel bearings and seals, etc. for my old 98 Dodge truck. Spent all afternoon painting the new rotors. Next day, went to install them. Guess what ? Yep. Wrong rotors. Wouldn't fit. Had to return them, get another set of rotors and paint those.
Old Jul 22, 2016 | 03:26 PM
Ls2_HHRss's Avatar
Yeah, if that is the case I will just Paint the old calipers and install them.
Old Jul 22, 2016 | 03:44 PM
Ls2_HHRss's Avatar
I'm guessing this guy did it as well. I have the same rear calipers as he does.
https://www.chevyhhr.net/forums/brak...-brakes-29189/
Old Jul 22, 2016 | 03:55 PM
BRACKET. Wheel Brake Cylinder/Caliper for 2009 Chevrolet HHR. #22705359
If you look at fitment, the bracket seems to be the same for Cobalt and HHR. Your HHR currently has rear disc brakes, right? Isn't the bracket you need already installed on your HHR?
Old Jul 22, 2016 | 04:07 PM
Ls2_HHRss's Avatar
Yes, I have 09 SS without the Brembo setup.
Old Jul 22, 2016 | 04:22 PM
Hey guys.
The problem I'm seeing is that the "new" rear rotors he's trying to install are a bigger diameter than any of the HHR SS ones. Brembos are only an option on the fronts of the HHR SS. The rear discs size is the same on all HHR SS's, Brembo equipped or not.
It won't matter if he has the stock rear brackets. Those brackets are for the ones with the 10.5 inch rotors. I don't see those brackets working with an 11.5 inch rotor size.
I still say a trial fitment is needed. Just thinking they should fit is asking for a letdown if they won't.
Besides the rotor size difference, there is also the E-brake mount looking different.
Old Jul 22, 2016 | 04:29 PM
Seems to be the same bracket for JL9, J56, J65, J66, J67. If your glovebox sticker has one of those codes, you should be good to go. Yours is probably JL9.
