Shorter shocks?
Old Jun 14, 2010 | 02:58 PM
robbie524's Avatar
Shorter shocks?
Does anyone know of a shorter shock to put on the rear of 2006 LT after lowering the back 2.5'' I got the road magnet springs and it just sounds like the shocks are bottoming out or something.. any help?
Old Jun 14, 2010 | 05:51 PM
lunchbox's Avatar
i went with KYB's replacement for the HHR, and they do not bottom out anymore. i didn't get any measurements for length differences when i swapped em, but they are shorter. i don't think your issue is the shocks though, the stockers didn't bottom out til the last 1/2" of the suspension cycle. it might just be the bump stops?
Old Jun 14, 2010 | 09:16 PM
robbie524's Avatar
ok so there are bump stops in the back? cause i only thought they were in the front of the hhr with the struts? cause i dont think i remembe cutting any bump stops on the back but i know i cut them in the front.. but i still think im going to go with them kyb shocks jus to be safe.. and if there is bump stops in the back im going to have to raise my car up and find them and cut them...
Old Jun 14, 2010 | 10:38 PM
bassbase's Avatar
HHR SS shocks are a tad shorter.
Old Jun 15, 2010 | 05:36 PM
lunchbox's Avatar
here's a pic i found in the gallery ( HHR Style ) of rear springs, just cut the bump stop ( thing in the top of the spring ) a little shorter. oh and if you bottom out the shocks hard enough, you'll shear off the lower bolt and the shock will shoot into your rim while you're cruisin
Old Jun 15, 2010 | 05:50 PM
Rodney B's Avatar
I used SS shocks on mine also.
Old Jun 18, 2010 | 01:06 PM
1 BAD HHR's Avatar
I too replaced the stock shocks and struts with the KYB's but I used the ones made to fit the SS. They are about 1" shorter than the stock ones.
Old Jun 19, 2010 | 09:59 PM
IgottaWoody's Avatar
Whered you find that.....KYB doesn't list a shock specifically for the SS.....
The GR2 rear shock is 16'' extended...........
All models have the same PN so you are not getting anything different, unless KYBs are shorter for all models
ssnick05
Jun 4, 2013 09:51 PM
retrolled
Mar 20, 2011 09:38 PM
Lee3333
49
Jan 24, 2011 10:27 AM
flyhhr
13
Oct 2, 2006 09:22 PM
