Spring rate rear suspension
Old Oct 28, 2020 | 02:15 PM
Blue_SS's Avatar
Originally Posted by Oldblue
So have you tried, clicking the adjustments from smooth to firm? Say 5 clicks at a time to see where you like the ride? Rebound will control the bounce not spring rate.
Technically, it's damping that controls the bounciness. As these guys said, you should be able to tune that out by going firmer.
Also, I think the spring rates are reversed. They are measured here in pounds per inch, and a bigger number normally goes where there is more weight. These cars are nose-heavy, so the front should have a higher rate.
My autocross car (not an HHR) had 224 in front, 194 in rear, for example.
Old Oct 29, 2020 | 11:49 AM
68greaser's Avatar
I try to set all 4 corners to firm. If its better, case closed. If not I'll replace the rear springs with a different type of spring. My wife doesn't want to ride along anymore, drives her crazy
Old Oct 29, 2020 | 12:53 PM
So that’s your secret!! Stiffen up the ride!!
Old Oct 29, 2020 | 04:40 PM
68greaser's Avatar
Recommendations on rear lowering springs (just in case) ? Struts in front are fine, I really think the promblem is in the rear section
Old Nov 1, 2020 | 09:59 AM
Ohiocruiser's Avatar
BC coilovers ARE stiff. A lot of people complained about it. That is why i went with kw1. Ride is almost the same as factory and you still can adjust the ride height.
Silverfox
May 27, 2015 02:49 PM
Miltown SS
Oct 30, 2013 10:56 AM
bowtieboy68
17
Jun 1, 2013 11:45 AM
Lake Runner
15
Sep 17, 2010 11:46 PM
