SS rotors on standard HHR
Removing the Flat Tire and
Installing the Spare Tire (SS Model)
The SS Model has larger performance brakes than
the Base Model. The compact spare tire will not clear
the front brakes.
Do not use the compact spare tire in the event of a front
flat tire.
You must use the rear tire to replace the front flat tire.
I know some of you guys run 16's after doing this SS rotor conversion, but I wonder if anyone has checked to see if the compact spare will fit up front ?
The spare rim being thinner and a different design,,,well, it just makes we curious.
I would hate for someone to suffer a flat and find out the hard way that the compact spare won't clear the "new" brake setup.
Maybe someone should clarify this or try it.
