SS rotors on standard HHR
Old Apr 8, 2014 | 08:43 AM
  #101
Well worth the time and effort!!!!
Old Apr 8, 2015 | 12:05 AM
  #102
JoelDirn's Avatar
Just finished upgrading the brakes on my 2010 LT. Thanks for the info in this thread. The swap went without a hitch.
Old Apr 8, 2015 | 08:35 AM
  #103
09BLACKHHR's Avatar
If I do Brembo brake will my stock spare tire fit the front? Thanks
Old Apr 8, 2015 | 08:52 AM
  #104
No.
Old Apr 8, 2015 | 10:04 AM
  #105
09BLACKHHR's Avatar
No.
So I need a SS spare tire? Is the SS spare bigger??
Old Apr 8, 2015 | 10:15 AM
  #106
I believe the SS owners with the Brembo's have to change the rear wheel to the front flat and put the spare on the rear!
Old Apr 8, 2015 | 11:10 AM
  #107
09BLACKHHR's Avatar
Really lol ok good to know thanks
Old Apr 8, 2015 | 11:38 AM
  #108
That is true Oldblue. It may also be the same procedure even with the non-Brembo set up. This from the owners manual:
Removing the Flat Tire and
Installing the Spare Tire (SS Model)
The SS Model has larger performance brakes than
the Base Model. The compact spare tire will not clear
the front brakes.
Do not use the compact spare tire in the event of a front
flat tire.
You must use the rear tire to replace the front flat tire.
I know some of you guys run 16's after doing this SS rotor conversion, but I wonder if anyone has checked to see if the compact spare will fit up front ?
The spare rim being thinner and a different design,,,well, it just makes we curious.
I would hate for someone to suffer a flat and find out the hard way that the compact spare won't clear the "new" brake setup.
Maybe someone should clarify this or try it.
Old Apr 8, 2015 | 12:11 PM
  #109
I have the non Brembo SS 11.65 inch brakes and the 16 inch steelies fit, but the spare tire doesn't fit, I'll have to do the front to rear swap if I get a flat!
Old Apr 8, 2015 | 08:35 PM
  #110
09BLACKHHR's Avatar
Wow I can't believe it ok thanks for the info
