SS rotors on standard HHR
Old Nov 28, 2012 | 06:50 AM
  #31
solman98's Avatar
Well, have about 1,000-1,500 miles on them and so far, so good. Very please with the stopping with these. The cooling fins look a little thicker than the stocks, so I'll curious about longevity. But the initial start has been good. I didn't have any issues with the last ones until about 17K miles, so I'll update once I pass that goal. With my driving, about a year.
Old Nov 28, 2012 | 07:21 AM
  #32
voigtsga's Avatar
Originally Posted by hyperv6
Yes I run 16" steel on my non Brembo SS evey winter since 08.
Thank you. I picked up the rotors last night and plan on ordering the caliper brackets today.
Old Nov 28, 2012 | 07:23 AM
  #33
voigtsga's Avatar
thanks for the update.
Old Nov 28, 2012 | 02:48 PM
  #34
IgottaWoody's Avatar
If you own a Panel or an 2LT,, you may be wasting your time with this mod as they already have the SS sized brakes on them from the factory(non-brembo)....but,it may be an improvement starting with a certain year and all inclusive with all years....check first!
Also, if you do have the big brakes..going to Brembos will be easier...
Old Nov 28, 2012 | 03:03 PM
  #35
voigtsga's Avatar
Mine's an LS, but that is good information to know.
Old Nov 28, 2012 | 06:23 PM
  #36
dkessman's Avatar
Very nice write up.
I just finished changing the rotors and pads on my 08 HHR SS. I used the Autozone rotors with Duralast Gold pads. I had 47,000 miles on the rotors and pads. I started to hear a squeal in the front, and found the front pads were shot. This was the easiest brake job I have ever done. Very straight forward just like the write up. Now I have nice smooth stops without the squeal.
Old Nov 28, 2012 | 06:48 PM
  #37
hyperv6's Avatar
They are a very easy change.
The only GM brakes change of late I had trouble with was on the GTP. The rear caliper bracket has one bolt stuck on the first change. I could not get a socket in on it with a bar. I did get it lose and after that everything else fell into place.
Old Nov 29, 2012 | 05:46 AM
  #38
solman98's Avatar
I would like to know where you came up with this? Every auto parts store I checked showed all LS and LT models (including 2.4 or panels) to have the exact same size rotors. Only the SS had the larger rotors. Most don't even designate a differance between the 1LT or 2LT, and only some even ask for motor size. But all showed the same size rotors.
Old Nov 29, 2012 | 07:28 AM
  #39
Putter's Avatar
*add to my to-do list....check!
Nice write-up, btw.
Old Nov 29, 2012 | 10:34 AM
  #40
Parts stores also show fe3 shocks and struts as a replacement for the fe5......Ask SSFan as he just upgraded...his panel had the bigger brakes stock..
