Steel LCA vs. Aluminum - Why not?
Old Apr 21, 2017 | 09:38 AM
IHRAcer's Avatar
I found this site while researching LCA replacement for my daughter's recently purchased HHR, and have read some valuable information. The one thing that I keep reading over and over is that steel control arms (Cobalt) aren't supposed to be installed on HHRs, with one poster stating DO NOT install them, even though it's been said that GM dealerships interchange the part numbers. I looked up the listed curb weight of a Cobalt and an HHR, and they're within 200 lbs. of each other, and the front/rear weight distribution is nearly identical as well. So my question is this: Can anybody tell me WHY you're not supposed to replace the aluminum with steel? I'm very curious to know.
Old Apr 21, 2017 | 10:04 AM
This has been previously discussed over and over again, as you well know. I don't think we need to open a new discussion about it.
Old Apr 21, 2017 | 10:19 AM
My answer is that Original Equipment means Original Equipment from the factory.
I am not so sure that GM interchanges the part number, more like they erroneously supply a different part number.
I am not sure why they were designed that way, but they must have had a good reason to use a more expensive part.
Old Apr 21, 2017 | 07:17 PM
GM OEM parts books do not show anything but the stronger aluminum LCA's, it the aftermarket that took it upon themselves to sell the cheaper inferior steel multiple piece welded offshore stuff. It's your dime , your life , your responsibility if they fail and involve you in a collision. Your insurance company will not cover you , because the parts aren't OEM quality.
agmc4me
10
Mar 31, 2017 12:34 PM
skyline26
10
Feb 14, 2014 09:45 PM
donbrew
Jul 17, 2013 08:29 PM
MarkD13
May 18, 2013 08:50 PM
damronjr
Oct 12, 2008 11:44 AM
