Still have rattle in front end
I have replaced the sway bar bushings 4 times and they only last a few months and noise is back. I have tried GM and then the red greasable ones. No difference. I noticed that the 06 sway bar 25 MM is no longer available. Would I be better to go with an 07 HHR sway bar ? Anything else I should check ? Thanks for any help. Car has 210,000 and runs perfect.
One more time in early 2015, but you didn't post when you replaced them the 4th time. Now it's late 2017.
Maybe they weren't even worn out, my 09 has 108,000 still on the originals. Have you replaced the end links lately? They often wear out sooner than the other components. Here's a link to help diagnose the front end noises https://www.chevyhhr.net/forums/prob...g-pop-s-50648/
Anyway, are you talking about replacing the sway bar itself? For VIN prior to 3GNDA23P26S546472 the bar is discontinued. For that VIN and after, you need GM P/N 15275280
TTR has a couple choices for new front sway bars Suspension - Turbo Tech Racing
EDIT: Looks like the FE3 may have the 25mm bar. All this info was laid out to OP back in Dec, 2014, when he was advised by donbrew to measure the bar.
06HHR sway bar bushings
my sway bar is part number GM # 15233085 but new ones not available. If I crossed it over right it takes 25 MM bushings. My suspension is FE3. can't find bushings except the red greasable ones which I have not had good luck with.
Where did you get that bar number? That seems to be the 1st design FE1 23mm bar. Are you sure you have FE3 suspension? You really need to measure the bar. But check your RPO sticker inside the glove box door and your VIN also. This could be an early car anomoly, would be good to document it.
That part number shows the bar is for the FE1 2006 HHR
https://www.mygmwholesaleparts.com/o...r-bar-15233085
Which we know to be 23mm
The bushing 20902785 shows it’s for the FE5 SS which is also known to be 23mm
https://www.gmpartsdepot.ca/p/Chevro.../20902785.html
So, you need to double check and measure the bar. I’m thinking you’re gonna find it to be 23mm in diameter. And that will resolve the bushing issues.
