Suspension Squeak In Cold Weather Fix?
I have the same bump noises, but I just saw on CNN (today 7:45pm est) that there may be a major problem with the Cobalt's steering system, "somebody is looking into it" was the ticker. Since we are esentially the same platform we could see a legit gripe? possibly connected?
Anybody out there with a 2010 having the problem ?????
I can't believe there is not a GM Bulletin out yet so Dealers can fix this problem.
Silicone Spray and Crisco ??????? GEEEEZ !!!
This Crap Smacks of Toyotas Attitude only it's probably not Life threatening.
People Don't buy a new car only to have unrepairable problems.
Mine had same problem. I took it to a chevy DLR they replaced Struts,sway bar links and steering column 90% of the noise is gone. Now still have a clunk noise on driver side front when going on uneven road or over dips or bumps. I have to drive slow over those. Also my traction control light came on and they didn't found anything. This has happen 3 times in 2 months. Taking it again this noise kills me and of course every time get TC LIGHT ON SHIFTS HARD. JUST GOT MY HHR 7 MONTHS AGO USED WITH 35000K NEED HELP.
I have an 06 with 227,000 km.(use it for work), have had the struts replaced, sway bar links done four times under warranty and twice after. I corrected the problem by using grade 8 nuts,washers and lock washers. The stock unit combines all three in one piece, the lock part strips and causes the clunk. After replacing the stock units, I have gone over 60,000 km. with no noise.
Ted
Ted
Fixed squeaks on my 2007 HHR LT
I have been having the same squeak as everyone else and discovered the fix was replacing the front struts and the stabilizer link bars. That may not be the fix for everyone but i have been going over speed humps since and no squeaks not even below 0 degrees. I replaced with Monroe Senso-Trac and Moog Stabilizer bars.
