sway bar for HHR
The seemly concern about hollow vs solid sway bars: hollow sway bars are a lot stronger in bending than solid bars. Ask anyone than does race car fabrication why they use hollow bar stock instead of solid bar stock. Hollow bar stock has a memory and will go back to orignal shape, where is solid bar will retain far less memory, and stay bent somewhat.
Seems some here, are concerned about hollow sway bars, and should'nt be.
"Moon"
"Moon"
Where would you position the floor jack ?
This is what the repair manual states:
2007 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1211728
(snip)
Automotive Lift and Floor Jack Contact Points
(1) Frame Contact Lift-Front Location
(2) Frame Contact Lift-Rear Location
(3) Floor Jacking-Rear Location
Vehicle Lifting-Frame Contact Lift
Front Lift Pads
When lifting the vehicle with a frame-contact lift, place the front lift pads 6.69 in (170 mm) from the front pinchweld flanges.
Rear Lift Pads
When lifting the vehicle with a frame-contact lift, place the rear lift pads 2.17 in (55 mm) from the rear pinchweld flanges.
Vehicle Jacking
Under the Center of the Rear Suspension
Lift the rear of the vehicle by placing the floor jack lift pad at the center of the rear suspension.
(snip)
I tried that one day, out of habit until I saw how far the beam flexed before the car actualy started lifting..Was not comfortable with 15-1800 lbs on one spot... if the beam was fully trianglated it would be diff....I use the hitch ..
eibach away bar
I fianssly had a c hance to try out the sway bar drove on a curvy mountain road I have driven hundreds of time some of the curves i had always would feel cautious at 50 mph today found I was driveing at 70 mph and felt good it made a diffrence,very happy with the sway bar.
Nice bracelet, BTW...
