Sway bar lateral lock
Old Apr 26, 2016 | 02:32 PM
webpirate's Avatar
I know whiteline makes lateral locks for the sway bars and the hose clamp with rubber is a tried and true method of laterally locking a sway bar but has anyone tried a bike seat clamp? Is there any reason why this wouldn't work?
http://www.sicklines.com/gallery/dat...ost_clamp1.jpg
Old Apr 26, 2016 | 03:35 PM
I don't know why it wouldn't, provided it is the correct size, it should provide effective clamping force.
However spreading it over the sway bar may cause it to snap in half, these might work better!
http://m.ebay.com/itm/251501514271
Old Apr 26, 2016 | 04:46 PM
Are the plastic locks broken?
Old Apr 26, 2016 | 05:14 PM
webpirate's Avatar
I don't have any lateral lock in place.. I put the poly sway bar bushings in and they allow lateral movement of the sway bar.. People have said to use hose clamps and garden hose.. But I thought maybe the bike seat lock would work too
Old Apr 26, 2016 | 06:04 PM
webpirate's Avatar
4X CNC Aluminum Superlight 25mm Arm Tube Pipe Clamp F Quadcopter Multicopter DIY | eBay
Yes! I am going with your eBay recommendation! Thanks!
Old Apr 26, 2016 | 06:50 PM
I've got the Energy Suspension polyurethane sway bar bushings, they don't move around on me, but my OEM plastic retainers are still intact.
You're welcome, let me know how the work out, please.
Old Apr 26, 2016 | 07:59 PM
Both HHRs I've worked on had plastic stops on the bar from the factory.
A little bit of lateral play is "normal". Assuning you were sold the correct size bushings.
Old Apr 26, 2016 | 10:59 PM
webpirate's Avatar
There are factory stops on the inner sway bar between the bushings but not on the outer(from bushing to sway bar end link/shock)
I don't notice any adverse effects when city driving but when I am on the highway and hit bumps in the road I can feel the front end shift over.. So I am not sure if the lateral movement is the cause but I am going to do the hose clamp and rubber trick until I decide what I am going to order online..
Old Apr 27, 2016 | 08:19 AM
webpirate's Avatar
After further investigation I can see that the bar is only allowed to move about 1 inch laterally towards drivers wheel and 1 inch towards passenger wheel before the inner factory locks stop it... Is that normal? Should I still lock it in a central position?
Old Apr 27, 2016 | 08:27 AM
That's normal, have a close look at your lower control arm rear bushings!
