Sway bar lateral lock
Old Apr 27, 2016 | 09:01 AM
webpirate's Avatar
Originally Posted by Oldblue
That's normal, have a close look at your lower control arm rear bushings!
Yes everything is new... OK I feel better now... Thanks..
Old Apr 27, 2016 | 10:08 AM
Cool! Now enjoy driving that HHR!!
Old Apr 27, 2016 | 11:39 AM
webpirate's Avatar
Unless the engine blows up I will be driving her forever.. I replaced every front end part with lifetime warranty parts..except for rear control arm which were pressed in at the dealer for free.... The only thing factory left is inner tie rod end...
Old Apr 27, 2016 | 01:07 PM
Originally Posted by webpirate
There are factory stops on the inner sway bar between the bushings but not on the outer(from bushing to sway bar end link/shock)
I don't notice any adverse effects when city driving but when I am on the highway and hit bumps in the road I can feel the front end shift over.. So I am not sure if the lateral movement is the cause but I am going to do the hose clamp and rubber trick until I decide what I am going to order online..
Thimk about it: If both sides are stopped on the inside why would you need stops on the outside?
Old Apr 27, 2016 | 02:11 PM
webpirate's Avatar
When I had the factory bushings there was zero lateral movement.. After upgrading to energy bushings the bar would move back and forth so thats when I looked into it an saw that there were locks to prevent this from happening but the locks are meant for after market sway bars that don't have factory stops and another user has informed me that 1inch of lateral movement is acceptable...
Old Apr 27, 2016 | 03:24 PM
Some have been sold the WRONG size parts. I think it may be a difference between ASE and metric. I also don't understand why you would want to grease them, that makes the slide more.
bporter436
Dec 1, 2014 03:44 PM
RBodeman
Jul 21, 2012 07:31 PM
kornellred
Feb 10, 2008 08:58 PM
