For those that are curious...
Old Jun 12, 2013 | 03:59 PM
Sounds like you just made your own set of YYZv2's. If them old ones were better than fe3's for my YYZv1's, on the Panel I would buy them from you.
Yes the coilovers will get you down there but to drive them hard, you have to dial them down to stiff. I believe the KWV2's will be on the craigs list soon.
Was trying to decide which struts, Koni or fe5 to go with a set of YYZv2's on the SS. I'm sure it wont be KYB.
Old Jun 14, 2013 | 07:37 AM
Dracos's Avatar
FYI, the springs for a Cobalt SS/SC and SS/TC are dfferent, one is much softer than the other, but I don't remember which offhand.
Old Jun 14, 2013 | 11:09 AM
mityqwik's Avatar
Thumbs up
post some pic's would love to see how it looks and also a very good write up
Old Jul 9, 2013 | 07:42 PM
skyline26's Avatar
haha nice i was thinking of doing the same but i was too scared lol..
chop up those yyz's and see if theyre any better
Old Jul 9, 2013 | 07:45 PM
skyline26's Avatar
i surprisingly have a big wheel gap still considering i swapped all suspension to fe5 and put on 18's ..i was parked by an ss the other day and im sitting higher not sure why :s
Old Jul 9, 2013 | 09:25 PM
IgottaWoody's Avatar
Currently considering hacking another half coil off...have a set of camber bolts ready to go..found that camber gets noticeably changed below 26 1/4 in of lip to ground measurements.For Some reason the left front likes to lay over..not so bad on the right front...geometry design i suppose. Will probably shim up rack box also...
Old Jul 9, 2013 | 09:54 PM
Will you make me some of them shims, I lost mine. They looked like this
Old Jul 10, 2013 | 11:40 AM
look easy enough.....havnt climbed under yet to have a look see
Old Jul 10, 2013 | 05:00 PM
jay loukakis's Avatar
I had suggested cutting the springs about 4 years ago, on site I was nuts to even think about cutting the springs Chip Foose does this all the time??
Old Jul 10, 2013 | 09:29 PM
I did it because they were just sitting there..most likely never to be installed again, sooo..i did it, wasnt happy with the current setup..these are much better..One coil cut brings you down to 26 1/4..wanting t bring it down another 1/4 and that should be about right and still be able to do daily things with it without having to worry about smacking things. The rear is going to be tricky..thinking of cutting top coil and adding a modified adjuster to set height..pretty much like what the coil over sets have. Since I have GL's on the LS, for comparative purposes, I think they had the correct set up..firm yet drivable..no bounce, even with KYB's...paired with a set of 17" wheels and 225/50/17 tires the ride is real good. Drove 3k miles cross country loaded down thru the mountains and didnt hear a complaint out of the wife..that counts for something....
