Torque steer
Torque steer
I have a 2009 SS panel with 6k a 5 speed and turbo upgrade. I'm experiencing some torque steer on heavy acceleration. I realize it's normal for front wheel drive vehicles but I'd like to try and minimize it as much as possible. Does anyone know of any half-shaft modification kits available for the HHR front axles with a 2.0 liter engine?
On your next occasion to check tq steer,, puch the TC button for 10 sec till the ESC OFF light comes on and try to tq steer it again......bet it doesn't
What I found is on occasion the car will actually try to seesaw ( or pull hard in the opposite direction I want to go) back and forth because the computer is trying to correct a spinning condition thus it modulates left and right trying to keep it straight....theres a small bit of a learning curve with these cars
One of the things you'll notice(under hard acceleration) is the right front dips and that sudden weight transfer will cause the car to go in that direction just like a low air pressure tire will. I feel that with adjustable struts and shocks you will be able to "dial" out the sudden compression experienced with those hard throttle on moments. In a few days I'll be able prove/disprove my theories.
Hmmm.... first time I jumped out to pass someone I had that eye opener..the car wanted to go right instead of left, pulling hard the whole way...I don't notice it now, but then after 26k I adapted...
It's about a 9 on the 0-10 scale of pucker factor. They must apply some brakes in comp mode because the torque steer really drops.
I don't get it, why does comp mode on or ESC off reduce the torque steer? If it does they must be applying brakes to one wheel reducing power to the ground (or at least adding drag to one wheel).
Or am I all wet.....
Alot of the percieved tq steer is actually the ESC/TC applying brakes to one side or the other to control differential wheel spin( thus the alternating side to side feel)...OR..its reducing power overall to accomplish the same thing....once turned off your getting full unadulterated honesttogod big boy turbo power to the wheels....this is where you better make sure your seat belts are on
