Upgrade to SS brake rotors
Old Mar 28, 2016 | 06:24 PM
pg318's Avatar
I followed the process in solman98's thread. Definitely a worthwhile upgrade. I bought some cheap rotors off ebay, but after 40,000 miles, and about 10,000 of them towing, there's still no warping, unlike the factory ones that were bad within the first 30,000 miles.
Old Mar 28, 2016 | 09:16 PM
skyline26's Avatar
Originally Posted by lazaino
I think I still have the ones I took off my SS when I put on Brembos. Free for the asking, located in Los Angeles. Calipers, rotors and likely the pads are still usable.
Ira
pm'd
Old Mar 31, 2016 | 11:59 AM
skyline26's Avatar
just to clarify...you can still use the stock calipers with this setup? so you are just changing the bracket?
or does the caliper need to be replaced as well? can you swap the caliper anyway?
Old Mar 31, 2016 | 12:55 PM
pg318's Avatar
This still uses the stock calipers and pads.
Old Mar 31, 2016 | 03:42 PM
Yes you only change to the SS caliper brackets and rotors for the non Brembo's
Old Mar 31, 2016 | 06:15 PM
Oldblue. I can't remember, but will the donut spare still fit on the front after the SS rotors are installed ?
Old Mar 31, 2016 | 06:57 PM
skyline26's Avatar
that is what i thought..ok thx guys
Old Apr 1, 2016 | 11:20 AM
solman98's Avatar
I tried it and it doesn't. In case of flat you have to put the spare on the back. Which with a FWD you should anyway.
Old Apr 1, 2016 | 12:32 PM
Nope the donut has to go on the rear!
Or dunked in your double double, mmmm double chocolate!
Old Apr 1, 2016 | 02:43 PM
skyline26's Avatar
OldBlue and Solman - how are your choice of pads and rotors holding up? What did you use? (semi, ceramic..) Need to do my front brakes and thinking of doing this "upgrade". I dont want any squeaking sounds or brake dust!
