I have a 2006 I have new tires, balanced & aligned; new stabilizer bars & control arm assy. I still get the knocking about about 40mph just a little & 60-70 mph more so. Not to bad with the new parts, not but its still there. What am I missing? Thanks!
Sway bar bushings. Proper torque on those lca rear bolts! Not just a rattle with an impact gun but 74 ft/lbs then tightened up another 180 degrees.
how is your upper engine mount is the serpentine belt tensioner bolt in the middle of the slotted hole in the right front wheel well?
If it’s to low to get a 15 mm socket on the mount is toast!
You say that you put on new stabilizer bars, I'm guessing you mean end links. Did you get the correct 10" links? Don't buy into the false claims that the 12" links fit, they are not correct.
