What's your HHR ride height?
Old Mar 17, 2013 | 07:06 PM
26 and a bit inches front and rear on KYB struts and shocks,with Canuck Motor
sports springs with 205/55 r 16 BF Goodrich Traction T/A'S on factory steelies painted red of course
Old Mar 17, 2013 | 08:31 PM
Your total tire wheel height should be close to the magic 26'' so that shouldn't matter. I had fe5 on my SS and it was at 27.5 front. Put the same springs with my fe3 struts and shocks on the panel, and got the same as I have now, 26.5 front and 27 rear. I might be where you got the info, but I used fe3 struts, not kyb.
Old Mar 21, 2013 | 03:08 PM
Franco Fanfuria's Avatar
I haven't checked the height on mine yet but it arises curiousity to check. I will check tonight. I installed the Goldline springs a while back and if my memory serves me right lowered it 2.75 in rear and 2.50 in front with the stock 16's on it. Now I went with the Solstice's 18's and I honestly think the less tire height compensated for the extra rim height and stayed about the same. Been trying to load both pictures for comparisson but my computers acting up! I'll try again tonight.
Old Mar 21, 2013 | 03:24 PM
IgottaWoody's Avatar
The HHRs all have the same front /rear setup..so the tire height will remain the same to around 1/4 inch because of clearance to the strut , regardless of rim size
Old Mar 21, 2013 | 06:01 PM
Snoopy's Avatar
I have an '06 2lt.....
It reads, ground to middle of wheel opening, 27.25 inches in the front, 27.875 rear.
Stock polished spoke rims, tire stock height, inflated to 36 PSI and 3/4 tank of gas. No additional load or gear.
I have SS springs and struts in the front, and SS springs and shocks in the rear.
Old Mar 21, 2013 | 06:15 PM
skyline26's Avatar
your sitting higher than Slide Rite at front when your on SS suspension all aorund..how is that possible?
Old Mar 21, 2013 | 06:25 PM
Snoopy's Avatar
Probably his 16 inch tires !!
But I might ad.....I have 55,000 on the car. About 10,000 on the suspension. So, maybe his mileage is a factor.....worn suspension?
Old Mar 21, 2013 | 06:31 PM
skyline26's Avatar
ahh maybe..oh right the LT came with 17's
Old Mar 22, 2013 | 11:21 AM
If I remember correctly my SS was the same..27.25 frnt..stock.. remember the FE5 struts are gas filled and tend to lify a slight bit compared to the non pressurized struts..this is why when you take them off they quickly expand to max height..gas. Ever try to collapse the rears? hard to do..well, this pushes the car up the same way.
Old Mar 22, 2013 | 08:59 PM
Slide_Rite's Avatar
I can't remember my exact mileage, but it's around 52k...I think. I'm sure my suspension might sag a bit...it's pretty low mileage, but still an '07.
