Wheel help
Old Sep 13, 2006 | 03:31 PM
SoCalHHR's Avatar
No Problem Dave - I wouldn't want to see you make a bad decision.
Wheels are a big investment!
Old Sep 13, 2006 | 04:09 PM
rdd's Avatar
rdd
Have you look at Centerline they have a couple of 5 star that will fit and they have a good price for 17in wheels at 159.00 each just look under Saturn or Malibu. at this address http://www.centerlinewheels.com/whee...ehicle&data=84
Old Sep 13, 2006 | 05:13 PM
RUDEINC's Avatar
If money isn't an issue Foose makes a real nice set, plus they are real close to what you are looking for. I checked into them for mine, but didnt want to shell out the cash.......Regards
http://www.mhtwheels.com/wheel.cfm?brand=4&cat=112
Old Sep 13, 2006 | 05:16 PM
SoCalHHR's Avatar
Unless you buy 16's, the Foose's only come in 8.5 wide...which is quite wide for the HHR.
I looked at them before buying mine.
Old Sep 13, 2006 | 05:43 PM
RUDEINC's Avatar
Originally Posted by SoCalHHR
Unless you buy 17's, the Foose's only come in 8.5 wide...which is quite wide for the HHR.
Yeah, some trimming would definately be involved, if the car will be lowered. Crowbar's are 8.5's I think.
I know these were 20x8.5 with a 35mm offset and 245/30/20 BFG's
SoCal, Do you remember what the offset was on the Foose Wheels?
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/06-lowered-lt2-20in-wheels-3469/
Old Sep 13, 2006 | 05:55 PM
SoCalHHR's Avatar
Naw, but they were too wide for my application.
Search around - it's on the web.
Old Oct 20, 2006 | 01:05 AM
lilbloohhr's Avatar
Wheel specs: 5 x 110mm bolt circle, 65.1mm hub diameter, +42mm offset (from rim center to outboard side). Now could someone tell me what the minimum clearance between the caliper & the wheel is? I got a good deal and would like to use these 15" steel rims from an '05 malibu for my snow tires (gotta save the aluminums - great white [salty] north, eh!), but I've only got about 9 - 10mm (~3/8") between caliper & rim with them on instead of the 30mm (~1-1/4") with my stock 16"s. There doesn't seem to be any interference but I wonder if there would be when things heat up, such as under heavy braking. Insight, anyone?
SouthGeorgiaHHR
Tires & Wheels
20
Apr 21, 2012 01:38 PM
O6ChevyHHR
20
Dec 24, 2006 07:58 AM
