Commonly Used Part Numbers A place to post commonly used OEM part numbers needed for routine maintenance and replacement parts.
Part Numbers for elusive and common parts - Broken into separate posts in this thread
Old Oct 3, 2019 | 09:11 PM
Fuel Line repair Kit:
Manufacturer - https://www.inlinetube.com/products/nfr0019
Ebay seller - https://www.ebay.ca/itm/202668477289?ul_noapp=true (if an obsolete link, search Ebay for "Fuel & Vapor Vent Line Full Kit 06-11 Chevrolet Chevy HHR")
For info and instructions, refer to https://www.chevyhhr.net/forums/how-...follies-62310/
Old Oct 4, 2019 | 07:43 AM
Awesome thanks
Old Oct 4, 2019 | 12:34 PM
Cat Man HHR's Avatar
Thanks Whopper.
Old Oct 4, 2019 | 08:48 PM
Originally Posted by cat man hhr
Thanks Whopper.
x 2
Old Nov 18, 2019 | 06:43 PM
terryk's Avatar
Interior door panel fasteners - The white/green clip that goes in to door usually breaks when you pry off the panel.
Black pin (on the panel) with white clip (goes in the door) - 11562256
Green pin (on the panel) with with yellow clip (goes in the door) - 11562257
Push pin- goes in side of door (push in center to remove, pull pin out to install and push flush to lock)
Ebony/Black - 22690838
Gray - 15341105
Old Aug 2, 2020 | 08:46 AM
m_ridzon's Avatar
LS/LT front struts,
Upper coil spring plates plate GM 22716379, the tab is to point towards the body opposite the steering knuckle bracket.
KYB Excel-G has struts, 339084 passenger side and
339085 drivers side
Moog K160052 strut mount bearing plates
the three top plate nuts are torqued to 15 ft/lbs.
the two knuckle bolts are torqued to 85 ft/lbs
The nut at the top of strut gets torqued to 52 ft/lbs
Please be very careful and use a coil spring compresser designed for MacPherson struts
Originally Posted by Oldblue
LS/LT front struts,
This applies to SS also.
Old Oct 27, 2024 | 07:45 PM
Rational Keith's Avatar
Tooks to remove panel clips
[QUOTE=terryk;878352]Interior door panel fasteners - The white/green clip that goes in to door usually breaks when you pry off the panel.]
There are plastic and metal tools to aid in panel removal, in Canada Canadian Tire and Princess Auto have such.
- kits of several widths of plastic pry bar
- metal tool like a bent flat screwdriver but with notch in metal end
Jit
Oct 18, 2019 06:24 PM
pyro panel
Canadian Mid East
0
Jul 6, 2010 12:45 PM
urbexHHR
Nov 19, 2009 08:19 AM
RoadDawg831
Apr 13, 2009 10:02 AM
joesblackhhr
Sep 27, 2006 04:03 PM
