2007 chevy hhr
Old Jul 30, 2021 | 08:59 AM
Okie dokie, thanks for clarifying that.
Old Jul 30, 2021 | 11:04 AM
Originally Posted by donbrew
Yeah, but asked the same question again on page 2.
Oh, I see it now, about the limited slip...
Old Jul 30, 2021 | 01:55 PM
weberr24's Avatar
So guys replaced driver side cv axle did not fix the problem still jerks and makes a popping sound with foot on brake and car not moving like i said in previous post replaced passenger cv axle about 8 months ago so don,t think it would be that side. So let me throw this idea out here my son is a pretty good mechanic he says it is the differential inside the trans that is the problem he says it has a open differential what do you guys think could it be that?
Old Jul 30, 2021 | 02:04 PM
I’m still thinking hubs!
Old Jul 30, 2021 | 03:14 PM
If it's hubs, does that mean that the splines have excessive wear? Or is it something else with the hubs?
Only things I think it could be is hubs, differential, or transmission. The CV axles was most likely. It could have worn out in 8 months, does it get abused(do you shift into drive while still rolling backwards, or into reverse while still rolling forward)?
The "all of a sudden" might mean something.
Old Jul 30, 2021 | 03:58 PM
  #26
It could be all of the above, the cv axles have apparently been eliminated, it is less likely to be the differential as the 4T45 transmission seems pretty stout. The hubs however are not!
Old Jul 30, 2021 | 04:25 PM
  #27
weberr24's Avatar
no i do not shift into drive are reverse while moving always come to stop before shifting and no it does not get abused while driving down highway it shifts threw all the gears fine. Could low trans fluid be the causes of the problem? Have not notice any leaks
Old Jul 30, 2021 | 04:31 PM
  #28
When was the last time we heard of a mechanical (not hydraulic) problem with the automatic trans-axle? Oh, never!
Have a look at these:
Old Jul 30, 2021 | 04:48 PM
  #29
weberr24's Avatar
https://youtu.be/YvKWGjmPKoc?list=LL
https://youtu.be/mGQWwPKjNkw?list=LL
Thanks I will check that out
Old Jul 30, 2021 | 06:36 PM
  #30
weberr24's Avatar
Ok guys this weird just drove to store and down the highway a little out of town stop put it in drive and reverse and few times no jerking and no popping sound what gives it has me baffled
