CV Axle or not?
Old Oct 29, 2017 | 08:05 AM
This shows how many GM vehicles this shaft fits.
https://www.chevroletpartsdepot.ca/p.../19209159.html
Not John Shaft, he’s a mean mother...
Can ya dig it, right on.
Old Oct 29, 2017 | 10:19 AM
I think that 2007 models in Canada has an extended warranty that covers a new column. I know that GM CANADA does cover all EPS motors for life. Special Coverage 10413.
Old Oct 29, 2017 | 10:42 AM
To clarify, the column is not covered up here in the great white north, according to my GM dealership.
I have that annoying rattle, which the dealership points out to me when I go in there ( I get my tires from them, best price, free balancing)
Fear not Don , I do all my HHR work here at home with my trusty wrench turner , Dan!
Old Oct 29, 2017 | 02:29 PM
Mine just always had a spot that felt like a universal joint turning over hard.
Old Oct 29, 2017 | 05:28 PM
Mine sounds like I dropped a screw or nut into it, but it only rattles over bumps and train tracks , frost joints on cement highways are amusing!
Old Oct 30, 2017 | 06:48 AM
  #26
aradmahogany's Avatar
Gregg gives a bit of a rattle over large bumps/train tracks too. I am going to be replacing my steering rack due to what I believe to be a failed inner or outer (or both) tie rod on the pass. side (give a good faint rapid popping noise when turning the wheel when stationary and occasionally in reverse, CV Axle wouldn't make noise when turning the wheel in park so that was a RO) and I was contemplating ordering a new I. Steering Shaft but I think I will save that repair for another day. While under there I'll visually inspect the joint and make my decision then.
Old Oct 30, 2017 | 11:19 AM
  #27
BERNS's Avatar
Update:
I went thru the whole car yesterday and found a few loose bolt that needed tightening.
Sway bar bolts were very loose so I went ahead and tightened them to spec.
Now the only thing I get when going over uneven is the rattle.
Old Oct 30, 2017 | 04:12 PM
  #28
I always recommend, got a rattle? Retorque the bolts, they do loosen up!
Old Oct 30, 2017 | 05:59 PM
  #29
BERNS's Avatar
Thanks.
How long can I go with the rattling steering column before needing to replace?
Old Oct 31, 2017 | 10:11 AM
  #30
Mines been rattling for over two years now LOL and I drive 30K plus miles a year so in normal people time thats about four years of rattlin!
