Differences between 06-07 and 08-11 auto Transmission/Engine
Old Oct 7, 2024 | 07:18 AM
  #51
Great, it’s fixed, enjoy the ride! Now snug up those fuse box bolts every oil change!
Old Oct 14, 2024 | 02:46 AM
  #52
Wheatgerm's Avatar
I will do so Old Blue and FYI I purchased a GMC Terrain in 2017 because it was the last year for the 2.4 as used in the HHR since I had a case of oil filters and other service items by the case as well and do you know what? The GMC Terrain has the same type of fuse and relay box [not identical] with the same configuration of bolts in it and they were loose so I tightened them the same day I got the HHR running right...I hope anyone that might read this will check any GM product they have to make sure their Fuse and Relay box is not separating...
Take care and thank you for the reply..
P.S, I've already had to put hub bearings in the GMC a few weeks ago at just under 67,000 miles..
Old Oct 14, 2024 | 02:56 AM
  #53
Wheatgerm's Avatar
I was able to get a Build Sheet for my 2008 2lt Auto and my 2010 SS Auto, axle ration among other valuable information is on those sheets. They can print it up within minutes and they didn't charge me for doing so, that being the Car Dealer I bought them from.
Emily Rose
Inactive Classified Ads
14
Sep 19, 2020 08:00 AM
jus1975
2.0L Performance Tech
Jan 6, 2012 09:40 PM
SS.lady
Maintenance and Upkeep
May 17, 2011 06:47 PM
T 20
Feb 19, 2011 01:59 AM
chooch
Jan 30, 2008 09:34 PM
