Front Hub Axle Nut
Front Hub Axle Nut
I have new front bearing hubs and planning to install this weekend. My question is the nuts for the rear axle hubs the same as the front? O'Reillys and Auto Zone only list axle nuts for the rear.
Weard that I saw them listed again for a cobalt and it says front. I guess I will just have to go by and look at what they actually have, I was trying to save a wasted trip but guess I don't have a choice. They also list two part#s one is for a cotter pin and the other is for a staked nut.
I had to reuse the front axle flange nut, strangely one did not come with the bearing hub assembly,I torqued to spec, drove 100 miles and retorqued to spec, if I remember correctly 155 ft lbs. no issue after three months and 15,000 Klms.
