Front Hub Axle Nut
Thanks for everyones input. I got the ones from OReillys, not sure why they say "rear" on the description but they are the correct nuts for the front axle to hub. It turned out to be a very easy job to do. I would say around 30 minutes per side and you should be on your way. 1. Take tire off, 2. Remove Axle nut, 3. Remove brake caliper and hang it from the strut, 4. Remove the three hub bolts, 5. One small tap on the side of the hub and it fell out of the bore and slide off axle spline, 6. Install new parts and torque everything back to specs.
