Hard shift, traction control service on, no solenoid codes
Old Jun 13, 2016 | 08:42 PM
Originally Posted by Arn2
I am interested that you say the vvt solenoids don't necessarily trip codes, because other threads I read said only replace them if the codes for them were set? If they don't always trip codes should I just replace them?
Donbrew is right - the solenoids COULD cause the problem you are having - but there is no direct evidence AT ALL, that the solenoids are at fault. And you are right in that the solenoids don't necessarily trip codes (due to drive cycles I suspect).
He is also right about it being rather futile discussing the issue until you get the actual codes downloaded and posted.
There are so many other codes and defective parts that can cause the hard shifting and T/C issues so suspecting the solenoids without any evidence to back it up is likely to result in you just throwing your money away.
Old Jun 14, 2016 | 06:06 AM
Arn2's Avatar
Thanks for all of your responses and help so far. Codes
P0449
P0030
P0036
P0053
P0054
P0102
P0443
Old Jun 14, 2016 | 07:15 AM
All of those codes together lead me to an electrical problem, most likely a fuse or 2 and/or a wire burned or frayed.
check under hood fuse #33 (controls all of the codes).
Old Jun 14, 2016 | 07:31 AM
http://www.obd-codes.com/p0449
http://www.obd-codes.com/p0443
http://www.obd-codes.com/p0030
http://www.obd-codes.com/p0036
P0053 - OBD-II Trouble Code | BestRide.com
P0054 - OBD-II Trouble Code | BestRide.com
http://www.obd-codes.com/p0102
All these have a common denominator, electrical!
Loose or burnt fuses, loose or burnt ground wires!!
Loose connection, bent pins in the connections
Old Jun 14, 2016 | 07:54 AM
If you find #33 is blown, find out why before you replace it. Probably a wire laying on the exhaust or rubbing on the engine.
Old Jun 14, 2016 | 11:34 AM
Arn2's Avatar
Thanks don. I'll check both as soon as I get it back from my wife. She found a nursing job with one of her former employers where they promised she wouldn't have to do any lifting and she needs it to get back and forth to work since her 16 year old Benz is down, again. But she won't get rid of it because it was her late husband's.
If anybody wants to complain about GM, try working on and buying parts for a 16 year old Benz!
Old Jun 14, 2016 | 11:52 AM
That's during the Chrysler debacle!
Old Jun 14, 2016 | 12:44 PM
Arn2's Avatar
Yeah, she gets upset when I call it a Mercedes Dodge. :)
But I should have more respect for the Mopar name. My brothers stock 340 duster could dust my trans am. Mine had 140 on the speedometer and I was doing it when he went around me.
But, at the end of the day, mine was a trans am!
I can't say the current Mercedes is in any better shape than it was though, a friend bought a c class a few years ago and it's been in the shop for three years because they installed the wrong radio in it. Messed up every system in it. But she's content driving all the loaners they've given her because it's keeping the miles off of hers
Old Jun 18, 2016 | 07:06 AM
Arn2's Avatar
Don, you are a genius! Fuse 33 is toast!
Thanks to everyone else too. Now I just have to go on a treasure hunt and find the likely assignable cause.
Old Jun 18, 2016 | 10:01 AM
Did the new fuse poop out too?
