manual trans shifter cable ends
Old Jan 29, 2019 | 04:59 PM
alexrckid's Avatar
i've got a 2006 HHR LT with the 5 speed getrag trans. anyone have an idea how you remove the shift calbe ends where the ends pop onto the balls on the trans..?? i tried by hand, they dont want to come loose and was apprensive to try to hard to pull them loose...
Old Jan 29, 2019 | 05:43 PM
Perhaps more leverage, then just your fingers
https://www.chevyhhr.net/forums/prob...removal-57685/
Old Jan 29, 2019 | 09:03 PM
The shop manual just says "remove the cable ends from the lever".
You might try a PM to fastsuv, he is still around.
Old Jan 29, 2019 | 10:11 PM
fastsuv's Avatar
When I removed my engine/trans (2006 HHR LT 2.4L) a couple of years ago, I just pulled them off the ball.
Yes, I also could not pull them off by hand and was reluctant to use more force for fear of breaking something..
However they popped off by using some leverage under the cable ends with a small pry bar against the trans housing.
Steve
Old Jan 30, 2019 | 11:22 PM
alexrckid's Avatar
great reply's guys....thanks. will give it a shot again.....
Old Nov 11, 2019 | 08:29 AM
Dan Bellman's Avatar
So my trans will not move side to side. So much so I broke the shifter. miraculously found one at the junk yard as they dont make them any more. Had it all fixed and working. Next day wont go side to side. How do I remove the metal bits on the top of the trans where the shift cables connect. To clean and referb the mech there I think that's my issue. Thanks. Hope this gets seen.
Old Nov 11, 2019 | 01:22 PM
It’s an ‘07 LT , so , have you sprayed any type of lubricant on the metal control portion of the shift levers?
Old Nov 11, 2019 | 01:29 PM
Yes PB blaster and wd40. As soon as they sit for any time frame it locks up. Is it easy to pull off the trans and like take apart and clean up.
Old Nov 11, 2019 | 01:32 PM
Perhaps FastSUV will chime in , he just changed out his manual transmission, perhaps he has photographs of the transmission out of the HHR
Old Nov 11, 2019 | 01:34 PM
That would be extremely helpful. Finding parts for this thing is getting increasingly hard or and picture or video on any media outlet.
