Please Help!! How can I bleed my clutch on 2006 Chevy HHR
Old Aug 9, 2022 | 02:06 PM
pdc's Avatar
pdc
It is grinding in Reverse and First badly and difficult to shift in other gears. When it sat for a few months after the issue it began to work great but then appears it got air again into cylinder or something.
Any assistance would be greatly appreciated.
Also if anyone knows if I can check fluid that would be great. Need a cheap and easy fix.
Old Aug 9, 2022 | 02:36 PM
The clutch hydraulic systems gets it's fluid from the brake master cylinder reservoir. Check the brake fluid level.
It can be bleed. If you're losing fluid, you'll need to repair the leak before you worry about bleeding the system.
Old Aug 9, 2022 | 03:42 PM
Several threads about the subject
https://www.google.ca/search?q=how+t...&bih=796&dpr=2
Old Aug 12, 2022 | 11:01 AM
The firewall has been a problem for some. It cracks where the plunger goes through and makes for incomplete disengagement.
Could be a bad clutch or throw out; 2022-2006=16 years, probably 3-500,000 miles.
2graphically
Mar 29, 2022 02:26 PM
fastsuv
7
Nov 4, 2021 05:25 AM
Sumthankool
May 16, 2021 03:40 PM
oneillja
Jan 4, 2013 08:08 AM
ghrtfldr
Apr 7, 2008 03:28 PM
