Shifting issuses
Shifting issuses
So I have a 06 just had the master cylinder replaced for my clutch and now when I'm shifting into 4th and 5th revs high after I let off the clutch and then shifts really hard not sure if it's transmission or clutch any help would be great
Why was the master cylinder replaced? What were the clutch symptoms?
Usually a problem that shows up after a repair is related to the repair itself.
However, a clutch issue would generally show up at all gear shifts, not specifically 4th and 5th.
It sounds like delayed clutch engagement after you release the clutch, first it sticks disengaged and then slams engaged.
Maybe air in the system, needs bleeding?
Can you give some more details on what is happening?
Steve
Steve
havoc3d
Drivetrain (Excluding Engine)
21
Dec 22, 2011 04:22 AM
