Possible Transmission Failure
Old Mar 12, 2012 | 06:58 PM
  #51
goetylsd's Avatar
Originally Posted by ChevyMgr
All transmissions will have some shavings in them. Did you see the fluid yourself? At your mileage I wouldn't expect the fluid to look new. If there were no chunks of metal or brass then a major component hasn't failed. By dropping the pan they only removed 5-7 quarts so there is still black fluid in there. Did they a put a new filter in it?
ChevyMgr-
I did not see the fluid myself as I dropped my HHR off in the morning, went home, and then they called me in the afternoon to let me know it was almost done. When I got there, they had already put the pan back on. What they told me, their words, was that there was "metal shavings" in the pan. They did not say there was "chunks" of metal or anything. I asked if a fluid and filter change would maybe fix it, and they said "that they doubt it would do much good, we'd probably be right back here again where we started a few months from now." Do you think a new filter and fluid change would be beneficial? I guess I had given up hope by now and was going to start saving up for a new or used transmission.
Tyler
Old Mar 12, 2012 | 07:11 PM
  #52
ChevyMgr's Avatar
I am not saying a filter change will fix, but now that you state it seems to be shifting correctly, it wouldn't have hurt to do that.
But since they think it needs replacing or repairing, I can see where they wouldn't put one in.
Old Mar 12, 2012 | 10:25 PM
  #53
It's a 50/50 shot. Back in the days when I serviced many transmissions with high mileage, we would always warn the customers about the odds. I've seen slipping ones cured and good ones sent to slipping like crazy. All because of a fluid and filter change. It's your gamble. Problem is,if it works out,how long will it last.
Old Mar 12, 2012 | 10:46 PM
  #54
X 2
Its like running through a cow pasture in the dark, half the time you miss the ----, and half the time you end up scraping your boots before you can go inside.
Old Mar 13, 2012 | 06:52 PM
  #55
But when the dealer says that they dropped the pan, but did not change the fluid, WTF. I believe that there may be a communication problem. More likely the dealer "pulled the dipstick" heh,heh and looked at the fluid. They just do not do that for free!
Old Mar 13, 2012 | 11:35 PM
  #56
Originally Posted by sleeper
Do you think they would put the Black trans fluid back in ? I don't..
Donbrew- that was my point as well..
Old Mar 14, 2012 | 11:35 AM
  #57
Old Lar's Avatar
There is no dip stick to check levels. If they pulled the pan, the fluid dumps out, so they must have replaced the lost fluid.
Old Aug 2, 2014 | 05:27 PM
  #58
Hey Thisstrangeengine,
I'm very sorry to hear of the difficulties that you have experienced. Feel free to send us a private message with your full contact information, VIN, current mileage, and dealership name and we will be happy to contact your dealer and discuss your concern with them. We will be happy to help!
Kristen A.
Chevrolet Customer Care
Old Aug 2, 2014 | 06:10 PM
  #59
Kristen A.
OKAY ALREADY, CCS is sorry to hear about 2 year old problems. Get a new canned response please.
Old Aug 3, 2014 | 11:14 AM
  #60
I think that was a response to a posting I had just moved into it's own thread, just prior to their posting. Call it bad timing.
agmc4me
Jan 28, 2015 07:25 AM
tntwolt
Apr 1, 2014 08:33 PM
Wolfblitz
2.0L Performance Tech
10
Dec 12, 2012 10:10 PM
ed.chrysler
Apr 18, 2011 09:31 AM
hhrbama
Jan 20, 2009 08:14 PM
