Problem with daughter's HHR
Old Dec 4, 2022 | 02:10 PM
PulpFriction's Avatar
Originally Posted by fastsuv
Interesting results from car-part.com, which I use to locate scrapyard parts.
When I enter 2007 HHR (which would have the donor transmission), it lists 2006 and 2007 HHRs as compatible.
When I enter 2011 HHR (which is the car that needs a trans), it lists 2009, 2010, 2011 as compatible.
Entering a 2008 HHR shows it as a unique year that only lists 2008 HHRs as compatible. Furthermore, it has two separate categories, pre-1/7/2008 and after 1/7/2008.
I assume car-part's compatibility is based on the Interchange books that scrapyards use. Or maybe not.
Steve
Kinda worthless info if there’s no mention of engine size.
Old Dec 4, 2022 | 02:59 PM
I think that is because of the aforementioned final drive ratio.
Well, no. they are all the same.
Those differences do apply to the engines.
Old Dec 4, 2022 | 04:08 PM
fastsuv's Avatar
I just realized that I didn't mention that my daughter's car has the 2.2L engine.
Also, all the car-part info I mentioned above is for a 2.2L engine.
I don't care if there are slight differences in final drive ratios. I am just concerned that the TCM is programmed for a certain drive ratio and may throw codes thinking the trans is slipping or other engine-speed vs output shaft speed discrepancies, when in reality the cause is a different ratio.
Steve
Old Dec 4, 2022 | 04:21 PM
fastsuv's Avatar
One other thing.
I put the shifter in park, and it is in park (car won't move or be pushed).
When I put the shifter in reverse, the car drives forward, but the backup lights are on at the rear.
These seem to indicate that the shifter is working.
Steve
Old Dec 4, 2022 | 05:31 PM
I don’t think you’ll have any problems the replacement transmission in Oldblue was from a ? No TCM codes.
Old Dec 4, 2022 | 05:44 PM
My Mitchell says all of the specifications are the same. I looked at 2007, 2008 and 2011.
Old Dec 4, 2022 | 06:45 PM
greg8453's Avatar
Sounds like the manual valve is out of sync.
Old Dec 5, 2022 | 10:11 AM
Perhaps you could elaborate on what the manual valve is and where it is in the 4T45E transmission, please
Old Dec 5, 2022 | 10:16 AM
I was just thinking about the problem, the pressure lines are know to crack at the welds
If there is a break at the welds, pressure can’t be maintained
Old Dec 5, 2022 | 10:56 AM
Is that connected to the disgronifier pump?
