Shift solenoid replacement.
Old Jul 22, 2024 | 11:13 PM
keithmason22's Avatar
When I put that in my cart at Walmart or Amazon it says that it doesn't fit my vehicle. What transmission fluid did you use. I have a 2010 Chevy HHR LT 2.2 automatic
Old Jul 23, 2024 | 06:34 AM
Originally Posted by Oldblue
yes, this is recommended transmission fluid .
Walmart does not have a clue what goes where.
Old Jul 23, 2024 | 07:25 PM
Did anyone have to take out the PNP switch? I would have to buy an alignment tool to put it back on but all videos i have watched no one has mentioned it
Old Jul 23, 2024 | 07:26 PM
Did anyone have to take out the PNP switch? If you did, do you have any tips?
Old Jul 23, 2024 | 08:09 PM
​​​​​​​Look in your Owner Manual if you don't believe us. Link in my sig, before you say you don't have one.
2006-2007 got Dexron IV at the factory; GM later changed the recommendation top Dexron VI for ALL HHR Automatics. Dexron is a specification not a brand.
Old Jul 23, 2024 | 08:29 PM
I’ve swapped out shift solenoids, never had to remove the PNP switch
Old Jul 27, 2024 | 08:07 PM
I just got done and went to put on the axle nut and the wheels are turning like it is in neutral but its in park. Any suggestions?
Old Jul 27, 2024 | 08:40 PM
Both wheels in the same direction? Did you mess with the PN switch?
Old Jul 27, 2024 | 08:58 PM
yes I had to remove it, but put in on the same way it came off without letting it move.
i just read the manual and its confusing
Old Jul 27, 2024 | 09:13 PM
yes both wheel at the same time.
