starting problems
starting problems
I haven't been active in a while so I'd like to apologize for that to begin...I have been so busy I don't check in as often as I'd like...so now for my problems
So yesterday I remote started my car and it ran for the usual 10 minutes ( I heard it start.) I went out about 15 minutes later and tried to start it to go somewhere and it just kept cranking and cranking and wouldn't fire:-(...so of course after a few minutes the battery dies. So today I charge the battery up with a jump from my truck and I checked with my meter to verify the voltage is correct. "dead" it was 11.9v(may have been good enough to start, i dont know)...charging it was at about 14.4v.... and I let it go for probably a half hour. so i disconnect everything and then check the battery and sure enough its at 12.8v.
I try to start it and nothing.. I get a flickering CEL and a bunch of service this and service that crap...I can hear the fuel pump... but I am afraid if I finally get it to turn over than I have other problems...or just the cold?
So next I check the start relay..34 under the hood...tests ok, but I change it out with the defog relay (same relay part number) and the same thing happens...
I also can't hear the start solenoid "hammer/click" noise...Its acting as if the battery is nearly dead but the voltage is proper..oh btw the battery is about 18 months old.
any input would be great!
I was pretty frustrated and should be more clear. Currently the car will not turn over. 12.8v present at the battery terminals.
The cause of where I'm at now:
The car did turn over for for a minute or 2 with me trying to start it and it eventually stopped ( I assume I killed the battery).
I checked all fuses and relays. To no avail.
I guess the only other info I have is the day before I took a 150 trip the was fine with the exception of a moment where the DIC said eng power reduced. It only came up for a half second and it was fine....no limp mode or anything.
Can the battery show 12.8 on the meter and still be done for? And if I had jumper cables hooked up for a while shouldn't it turn over?
Ok so some new info. The battery dropped from 12.5v to 11.5v or so when I tried to start it. Is this normal if it doesn't turn over? Thanks for thehelp I appreciate it:-) .
I can't get under it until tomorrow with some daylight
