trans swap 2008 to 2010
Old May 18, 2023 | 06:52 AM
glassdave's Avatar
Just picked up a high mile but running 2010 Panel and am putting pieces together to do a full driveline rebuild. Rather then rebuild whats in it i am going to do a seperate engine and trans then swap in when done. The panel is a 2010 2.2 VVT automatic and i have a 2008 2.2 non vvt with around 100K on it that id like to use the trans from. Will this interchange with the 2010 alright? plan is to get another 2.2 VVT engine, rebuild that then assemble an entire drivetrain to swap in. Thanks all . . .
Old May 18, 2023 | 07:32 AM
The transmissions are the same. Engines not so much. You might need to do some serial number matching in the computers, probably not.
To get thing totally correct the ECM will have to have the crankshaft variation learned, if you don't swap ECM to engine. Should be done anyway.
Old May 18, 2023 | 08:14 AM
I’ve swapped 2007 automatic to 2011 2LT , shifts and runs nicely.
as for the non VVT to VVT , that’s a no go.
Old May 18, 2023 | 03:46 PM
glassdave's Avatar
Thanks guys, i kinda figured it was a no-go for my 08 non VVT into my 10 VVT engine bay. I was mostly curious if the 08 trans was compatible because i know the mileage and that it was in good working order, i bought the 08 as a complete wrecked parts car. I am going to keep my eyes out for a proper coded 2.2 VVT to rebuild but its good to know the trans part of my plan should work. BTW if anyone wants a free good running 2.2 non VVT engine its up for grabs.
Old May 18, 2023 | 04:01 PM
While that transmission is out of a car, change the shift solenoids, much easier than in the car!
Old May 18, 2023 | 04:16 PM
glassdave's Avatar
way ahead of ya and with genuine GM parts to. I did the shift solenoids in my 08 Panel and while it wasnt as bad as i thought it was gonna be, yeah any time i have a trans out its getting solenoids
Old May 18, 2023 | 05:38 PM
Good idea!
Thru the driver’s side dropping the cradle and transmission isn’t to bad , much easier out and either on the floor or a bench !
Old May 18, 2023 | 07:59 PM
glassdave's Avatar
Good idea!
Back when i did my solenoids i just followed all the great help on here and in all honesty after what i learned in the tech threads and doing it myself i feel i could probably do the whole thing in about three hours. Definetly some good knowledge to have with these cars. Really looking forward to rebuilding the driveline in the new to me Panel. Might have to see if i can gleen some performance tips and tricks off the site here.
Old May 19, 2023 | 04:44 PM
greg8453's Avatar
Information is valuable.
uluz2a6
2.2L Performance Tech
7
Jan 13, 2021 07:09 PM
Kirk Evans
Mar 4, 2020 08:10 AM
harvardman
2.0L Performance Tech
Nov 4, 2018 06:41 PM
bugo
Apr 30, 2018 03:54 PM
Talvanos
Feb 7, 2011 08:59 AM
