Transmission Turbine Shaft O-Ring
If our camera lens is on the torque converter it has to be #41. The shaft connect the 2 sides of the housing the chain drive on one side the TC on the other. The TC is the "turbine".
Update for anyone strolling through here with a similar question...I confirmed it is #41 and the GM part number is 08677453. The o-ring arrived from RockAuto and was installed over the weekend.
intruderdct
Drivetrain (Excluding Engine)
04-03-2017 07:54 PM
SindyDix
18
07-27-2006 02:21 PM
